BigRockJeep
- Sonoma CA
Hey all,
I am a TJ owner about to help my brother lift his '91 XJ. I have "searched" your board, and resorted to starting a new post as neither of us have lifted an XJ before and couldnt find the answers needed.
So, here is what we have:
1991 XJ w/231
Teraflex 1.5 spacer/shackle lift - installed
RE 3.5" SuperFlex kit - to be installed
So, the question is....What else will be needed to install and run this setup. We will be using both kits together & this will be a daily driver. Here are my thoughts so far:
Upper control arms
Ext. brakelines
Rear Driveshaft
Front trackbar
Longer shocks
Pitman Arm??
SYE Kit???
T-Case Drop Kit???
Any thoughts/suggestions will be greatly apreciated. Is it true that the RE 3.5 will be more like 4.5"?
Thanks for the help!
JP
1991 XJ w/231
Upper control arms
Ext. brakelines
Rear Driveshaft
Front trackbar
Longer shocks
Pitman Arm??
SYE Kit???
T-Case Drop Kit???
JP
