boostamante
- los angeles california
To break you![]()
Well then Mission accomplished Cause i am balls deep in debt
To break you![]()
Well then Mission accomplished Cause i am balls deep in cracker![]()
If his was a budget build then what the hell was mine?![]()
Yours was 'budget' but we spent to accomodate your long term axle needs.
Beamer has a lot more money to spend. We need to gear/lock and convert it to 4WD still and now he is talking about biting the bullet and getting an Atlas.![]()
I vote you get some more pics of that track bar and drag link setup...
There is only one pic. The DL/TB are about the same length and angle. It will be less of an angle after he gets the high steer on.
I'm more concerned with the bracketry, etc on the TB. thats pretty much the exact histeer setup I want to run on my 30. with heims of course:roll:
Now that it's fixed-ed can we swap?
Cool beans on the progress. I need to address some things that irritate me on my Rig. One of them being the spot where it gets stupid hot right behind the passenger seat above where the Muffler sits. Last time it smelled really bad when i drove out to Forrest falls and some smoke was coming from it. I threw some water on the carpet and all it did was steam it right off. No bueno! Other than that i want to add some leafs to the pack as it finally settled and it sits a tad lower still in the rear.
The cat probably got pushed up into the floor closer than it should be. I have some insulation for under your carpet that will help as well.
Is that where the Cat resides? Right aroud the passenger footwell?
