chemsolder
- Texas
Well I grabbed an XJ up on Monday evening and it is a true project for sure. Good news is it doesn't throw any nasty engine codes bad news is it leaks a little oil. First things first I have to get it to pass inspection and get her titled...
Job one is the emergency brake so Here is my solution.
The button came off and who knows where the spring is...
So a simple steel collar with a set screw a spring and a washer, all appropriately sized...1/4" on the collar the spring was out of a worn out Yamaha pw80 carb and a washer from the parts bin.
Put the washer on then the spring put some tension on it and tighten the collar down with the set screw. The washer keeps the spring from sliding into the slot. This is functional now but not comfortable.
notice the button wont fit back but with a bit of dremel work and a bit of epoxy it will be good to go.
I hope this helps some, lurking here sure has some good ideas in my head!
