ADV_XJ
- Riverside, CA
Hey there, everyone. New to the forum. Somewhat new to XJ's. I've worked on hot rods and have owned a bronco in the past.
So, I picked up this '96 about a month ago with 180,000 miles. It's in pretty good shape, but has a few things that need attention.
It has an 8" Rusty's long arm lift (too high, I know), 35s, locked 8.25 in the rear, Dana 30 front, and 4.56 gears. No SYE, which has led to concerning vibrations. I have already purchased an advanced adapters SYE and it's waiting to go in.
I need some help regarding making some changes to the XJ.
Firstly, I'd like to lower it by swapping the front coil springs out to 6.5" coil springs. Is this doable with the 8" long arm kit? I'm aware that I'll need to trim and bumpstop to fit the 35s. I'm guessing I'd have to adjust the control arms and buy new shocks of the correct length?
Also, the jeep seems to ride rough as s*** over small potholes and such. Just lots of vibration being transmitted to the cabin. Could this be due to improperly adjusted control arms? Poor shocks? The current shock bushings seem to be egg-shaped and blown out.
Regarding the SYE install, the current pinion angle is shimmed so that the diff yoke points directly towards the transfer case. I have read that the pinion angle should be parallel to the transfer case output shaft angle. Would simply removing the existing shim level out the pinion angle?
Here are some pictures of the rig and suspension components for reference. Anything stand out as alarming?
Thanks in advance for any help. Looking forward to getting to know some of you guys and perhaps going on some wheeling trips.
