New Hesco heads
XJZ said:
But we're talking Hesco heads and the Jeep 4.0
30 h.p. head and -30 lbs. That's a tough call?
No your right. I just meant IF there were two exact heads available, one in iron and one in aluminum for me it would be a tough choice.
B
Well one simple thing that can be changed is your ignition timing. with an alum head you can run more advance there for more power(to a point) with ou detonation since the combustion chamer will be cooler.
I believe there is some confusion here regarding the aluminum vs iron debate. The difference is heat transfer. The more heat that is transferred into the coolant, the less efficient the combustion process is, period. Iron doesn't transfer heat as well as aluminum and is therefore a more efficient material for reducing heat transfer. Engines with aluminum heads require more compression to offset this energy loss. Heat that goes into the cooling system is wasted energy. Keeping as much heat in the combustion chamber as possible is more efficient, pure and simple. As was mentioned previously, heat reflective coatings on the piston crown, combustion chamber and valve faces are good solutions. Getting the heat transfer qualities of iron with the weight savings of aluminum is the best way to go.
Thanks man, at least I'm not the only one trying to explain this now.
B-loose
I'm with ya now Bloose. The arguments for more compression and advanced timing were what I've seen before. But I completely understand how the slower heat transfer makes the effieciency higher. Now, about that HP/ weight ratio thing.....
These are up to $1995 now on their website. Why, oh why, did I not have $1000 to spend on them 4 yrs ago?!
Especially when you have to deck the block to raise compression for the full 30 HP gained...
For Jeepspeed rigs built to go fast in competition... sure.
For my rig... 258 crank / rods + mid grade gas & call it done.
That matching $4-5K aluminium(when does the new season of Top Gear start?) block will be out . . .
..and add the Hesco RVOB cam, '99+ intake, injectors, and Unichip with dyno tune. It ends up being a hugely expensive 30hp gain.
$7k for an aluminium block and aluminium head in a Jeep that's worth less than $3000? I don't think so.
By the time you get done with Hesco's all-aluminum 4.x or 5.0 (whatever) stroker, you're making 300-350 horse with a 7.5K build cost in round numbers... The AW4 probably wouldn't last too long behind that sort of power. I wonder what it would take to get an LS series chebby in there?
It might last about 5 minutes.
A lot less than $7.5k that's for sure.
doesn't aluminum not take to heat too well? I know on hot days on the trail when im really working my poor jeep the temp really gets up there if I don't pay attention. I would be afraid to warp a 2k head
Aluminum is more efficient at heat transfer than iron (note the discussion above on CR under iron vice aluminum.) If you've got an "all-aluminum" engine, the block and head will expand at the same rate.
The MLS composite head gaskets came about because people were trying to seal aluminum heads against iron blocks, and the head gaskets were "scrubbing out" with head (aluminum expands twice as much as iron, for a given temperature and size.) Single-layer head gaskets were losing seals because they were literally being scrubbed away over time. Thus, the MLS gaskets.
Sealing aluminum/aluminum or iron/iron isn't much of a problem - since everything around the gasket expands at the same rate, the gasket simply gets stretched and released - no scrubbing. The MLS gaskets are still better (the outside sealing layers stretch and release, slipping around the steel core,) but they're not as necessary as they are when sealing aluminum/iron.
This is why the Buick 215ci V8 worked so well for Land Rover for so very long (LR bought the tooling for the Buick 215ci all-aluminum V8 engine in the late 1960's, and used it in the Defender "series" models - mainly the D90 and D110 - ever since. These engines crossed the Sahara without mishap, so you know they're at least reasonably good...)
You could go with something like the Level10 trans, www.levelten.com ,but then you add another 3k+ to price tag.
the aw4 is a hell of a lot tough than you think stock and then built its the same trans that turbo supras are using and pushing 900hp. wasn't some one here using a aw4 behind thier 401 powered drag mj.
A stock AW4 yeah, not a good idea. But like Red said, the Supras run this same setup. A NAXJA member actually has a "hyrbid" AW4. Basically took the internals out of a Lexus AW4 and rebuilt his. Its been so long since I've researched it, but pretty sure the LS 400 (V8) has the AW4.
