new control arm issue....
holy crap, why would you do that?
disturbing.
on a different note, i ran into a guy who had some brand new "traction bars" basically 2 30" long control arms... ive got 4 brand new johnny joints sittin around, what do you think about hacking off the bushing ends, threading the tubing, and welding in the jj's... what else would be needed, a new crossmember with mounting points tied in... or should i scrap the idea??
needtofinishmyrig said:
disturbing.
in response to your hijack, there's a lot more to a long arm setup than just "long arms." the dynamics and kinematics of it are very critical. unless you do a complete analysis, it will probably work like crap. do some searching if you're really interested. check out the fab section. i know a handfull of people on here that have made or are in the process of making a custom long arm setup, but they all started by doing their background investigation.
i appreciate your response, i wasnt so much concerned with the geometry of the system, more of whether or not these "traction arms" would function well and hold up to a beating. i know not all control arms are built equally, but if they were built to lift a ford or chevy, they should be plenty beefy for my application right???
GauchoMD said:
Oh, thats a weld?!?!?? I though it was black bubblegum holding it together...
Same difference (strength wise) :)
I should add, specifically, taken away, and given to me. Someone who will use it properly.
jeepxj91' said:
well i finally got the control arm project done here are some of the finishing shots....
:puke:
