4.2L = ~260ci
260ci/2 = 130ci (you only move air for two of four strokes, or one of two RPM.
130ci * 4500 (estimated max RPM) = 585,000cim
585,00cim/1728 (ci per cf) = ~338.542cfm
Follow that? It's really a fairly simple calculation, once it's broken down.
The primary flaws are thus:
- I don't know your exact ci displacement - but 260 is "close enough for government work."
- Jeeps don't get the engines redlined very often - 4500 is probably too high, but that can be easily changed.
- This doesn't take into account the volumetric efficiency of the engine. This depends on a number of factors, but we can usually take the VE of the AMC six to be ~75-80%. 85% would be an "outside best." Therefore, you're probably flowing ~288ci, tops (assuming 85% VE - which is high.)
However, even with these flaws you'll still get a useful answer.
