SINCITY192
- Bronx, NY
Ok winterbeater
i'm doing this step by step so i dont get confused
I have everything hooked up with the exception of the 2 blue wires that i disconnected from the switch i also tape the ends so they dont ground anywhere!
with that said
the rear tail lights plug in on both sides so I want sure if you wanted me to check both of the plugs(connectors) so i just check the one on the driver side behind the spare tire! I touch the probes together and the meter read from like 0.12 then went down to zero, (0.00) thats with the teo probes touching together
I tested the connector coming from the front driver side that connects to the tail lights.... Checkong in ohms I got the same reading it goes from a high number down to
zero as if the probes are touching
so what does that tell me that the short is within the wires that are disconnected from the switch?
