ok to start off- 1993 xj, aw4, 4x4. 4.0 h.o.
so i have only used a multimeter once before. used it to test my CPS following these steps:
TESTING PROCEDURE 1991 – 2001 4.0L H.O. engines
1. Near the rear of intake manifold, disconnect sensor pigtail harness connector from main wiring harness.
2. Place an ohmmeter across terminals B and C (See Image). Ohmmeter should be set to 1K-to-1OK scale for this test.
3. The meter reading should be open (infinite resistance). Replace sensor if a low resistance is indicated.
so my multimeter only has settings for 200 and 20k. regardless i used 20k to test and 200. both times the meter only read .1
now if there IS resistance should it beep if the setting on the multimeter is set to it?
Does .1 mean low resistance and i need a cps?
what should it read for open (generally since all multi meters are different)
manual wasnt helpful, that is why im asking you guys.
please explain all of this to me like im 5.
