- on the beach in Ocean View, VA
How about slightly bumping the fuel pressure and leaving the MAP where it is?
I'll preface this with "I don't know what the answer is, but..."
short term, the increased fuel pressure would probably work, but I would assume a properly functioning O2 sensor and ECU will see the "too rich" mixture and start to pull fuel from the motor.
I might try a longer arm on the throttle body to slow the rate that it opens. I know it isn't the best solution, but a proper mixture into the engine with a little slower throttle opening will probably run quicker than more air without fuel to compensate for it.
