WB9YZU
- Madison, WI
It was a mind bender. However,
You can hover an aircraft, you just need a stiff headwind <kinda fun>
If you take off with the wind, it will take you longer to achieve the needed windspeed to take off <not so much fun>
The theory behind the experiment was flawed.
The prop produces thrust, and it's opponent is drag, not ground speed.
As long as you have a fairly friction free set of landing gear, drag is not an issue, so the equation remains thrust vs drag. Once the aircraft has achieved the required wind speed, it's gone. And that's exactly what happened.
I was suprised thy found someone with enough kahunas to put their sport plane on that rag they called a "Treadmill".
