Mystery leak
Z.m4v
I have a 1996 jeep xj, 4.0, 2wd aw4 from a 2000 xj. I recently replaced oil pan gasket and the rear main seal. However I still seem to have a leak. Is it possible that I messed up the install on the rms because the oil filter adapter is not leaking and the valve cover gasket it good as well. The only other thing I could think of is the transmission seal is leaking but I'm not sure about that because there is fluid on both sides of inspection cover
Leak presenting at inspection cover bolt:
Oil mess
The difference between oil and atf should be obvious!
