My Ranger build
1freaky1
Thornon, CO
This started out that I was not even looking for a 4x4 or even a truck for that matter, I was searching for a Mustang. Dad & Val (my wife) talked me into buying a 4x4 truck.
Since I was already pre-approved on EBay for 20k I looked at the rangers since I have previously owned 4 of them. Anyhoots I bought this one from a Nissan dealership in Chicago and had it shipped here the Denver. It was completely stock w/ 57k miles showing.
Over the last four years this build has turned directions from just a set of bigger tires, and better bumpers to where it is today, custom bumpers, full exo cage, front & rear winches, sliders, semi flat bed, shortened rear of truck, 35" Goodyear MTR w/kelvar, on board air, 3" body lift, FS HP D44 & 9", lengthened radius arms. I fabbed everything myself.
Future plans are to do a 203/205 doubler, and then a 5.0.
stock at dealership
1st go around w/ light bar and 32s
with new rear spare tire / gas can carrier and bumper
cross support done and bumper narrowed and raised
rolling chassis I picked up for the HP D44 & 9"
bed framework coming together
bed all fabbed up and rear is now 1 foot shorter
New tail lights installed
new rock guard for fuel filler done
teaching my daughter to use plasma cutter
9" housing all cleaned up and ready to build
Coil buckets lowered and welded in along with 1/4" gussets
Dana44 under truck for the 1st time
cleaning up stock 79 Ford Bronco radius arms
cutting the 1-1/2x 1/4" DOM for lengthening the arms
cutting the radius arms
Actually looks pretty good.. Tubing around the fenders looks a likkle hokie.
welding in the bungs for the new Creeper Joints
showing the difference in length of how much longer the arms will be
DOM notched for arms and welded up solid
next is to get the wedges welded to the D44 once I redo the radius arm mounts to a removable cross member, then to get started mounting up the F150 steering gear box and order my new tie rod w/ 1 ton chevy ends
you love over by Thornton Elem dont you??? I have seen you ranger alot. I passed by it every day on the bus and got to see the build from the bus lol. DEff a sick ass looking ranger
