- South San Francisco, CA
I'd do the frame stiffeners first then weld the crossmember to them.
i don't get it, super beefy arms from them and only two bolts for their x member? And that looks like a 3 link x member so how are you gonna do 4? radius arms? in which case would be super sketchy with only 2 or even 3 bolts. I would add more material to make a 4-5 bolt x member.
Mike, Zac currently has a set of re radius arms that he got from chris. So he is going to run those for meow, until he can afford to go to 3-link. The directions from Clayton say to weld the mounts as well. The middle is removable by bolts.
saw your post about tranny issues on Dr. My phone won't let me post over there so I'll post here... I had the same issues with my 96, turned out to be the 1-2 solenoid.
sounds like solenoids. you can test them all at the TCu. its pretty easy with a multimeter.
i forgot how to test them, been a few years since i've dealt with an aw4 issue. But each solenoid is only held on with one bolt, you can get to it after you drop the pan. Super easy fix dude and way easier than dropping the whole tranny. tcase's are a hell of a lot easier than a tranny. Getting in that tranny tunnel to the top bolts with a torx socket sux big ballsac.
Never seen strawberry milkshake before.. Is that what the trans fluid looks like too? Or just the trans fluid pouring into the rad?
