- Harrisburg, NC
1. Been using the AC or defroster a lot lately? The drain for the AC is on the passenger side and may be clogged up. Next I would look for leaks around the windshield, door, and where the HVAC Blower Motor sits on the firewall. You'll need a buddy to blast the Jeep with the water hose while you sit inside and look for leaks.
2. I really like BDS for something that's a daily driver/weekend wheeler. IMO, they're not very expensive at all and the ride is excellent.
4. How's your alignment (toe)? If you didn't re-align it after the lift, it's not in spec and that will cause tire wear quite quickly. How often do you rotate your tires?
