- Roanoke VA
Coolers might be in the same spots ... but our clutchfans arent ..
Have you tried on the other side as an experiment ... or have you got a fan over-ride on the e-fan - so you dont have to wait on the PCM to finally activate the e-fan ??
Are you still hooked up to the tranny oil, heat exchanger in the radiator ??
All are great questions, I can move it to the other side without issue.
No over-ride on the e-fan, mine is 96 and from what I have read, if I over-ride the e-fan I will get a code.
I spent last night looking at different e-fan set-ups. Part of my air flow issue is that all of my wheeling is in the rocks and I'm moving too slow to get air across the grill. The winch is not helping much either.
No, I'm no longer using the heat exchanger since this rig is rarely used in the winter(our trails close after bear season is over and re-open in the spring)
