xpedition xj-eh!
- Calgary Alberta Canada
I'm 6'2 and my legs are too long for my 97 and 99 4 doors with non-power seats. I'm moving my seat mounts further back. I've never had a car where I don't max out the leg room.
In the pic below you can see the main seat bracket in the lower right corner. It's a channel shaped piece of steel that is spot welded in. You need to relocate that an inch or so rearward. The trick to removing it is to drill out all the spot welds. It's not that hard to drill them out. That's where I'm at now. Then you can move it back an inch and bolt or weld it in. The rear of the seat bolts to the floor. I haven't figured that part out yet but I would imagine it involves drilling holes in the floors. I'm halfway though this so use this info as you will.
