90Blue_XJ
- In yer postz fixin yer spellinz.
BlackJax said:The radiator portion of the cooler doesn't do much, at least it didn't for me. When I bypassed it with a standard 10" Hayden cooler (aluminum), it dropped my temps 25-50 degrees lower than when the radiator cooler was plumbed and circulating to the Hayden.
Did you plumb in a trans temp sensor and gague to monitor the trans fluid temp? I think that would be a good safety measure if you bypass the radiator cooling and use a strictly Hayden setup. The factory must have had some kind of plan when they put it through the radiator and an extra cooler on trucks with towing package like my buddies CTD.
