GSequoia said:This is a run, tow points from and rear are going to be mandatory.
Andy Steiner said:If anybody on the run still wants to attempt to cross Soda Lake, you're welcome to do so, but I won't be leading you. I'll meet you on the other side. I suggest you have a GPS, a camera, a shovel, a Hi-Lift jack and eight sheets of 3/4" plywood cut into pieces two feet wide and four feet long. If you do get stuck you can stay on top of the mud by using the plywood. While your rig is floating on four of the plywood sheets you can move the other four in front and just hopscotch your way onto firm ground.
sintax said:I am either going to sleep in my Jeep friday night, or I may just bite the bullet and get a room at AVI. I checked it out and it looks like its gonna be $65 for a room for that friday night. Maybe i'll get there early, blow some funds in the casino and see about getting the room comped :dunno:
Soda Dry Lake is the great basin in which the Mojave River empties. As long as the river runs, it's not going to dry out. The only question is how deep the crust is.coreyva said:It's got two weeks to dry out. You know I have to try it Andy.
karstic said:Alll the long range forecasts I've seen call for mid 80's in the day and mid 50's at night-pleasant spring-time desert weather.
igavryus said:About Soda Lake detour. Is there way from I-15 to Mojave Road through Zzyzx? Would be interesting to take a look at that place.
I don't mind at all. Michaelle and I will be leaving the San Fernando Valley about 12:30PM on Friday.igavryus said:So we decided to change plans and stop at Goffs if company does not mind.
The Desert Studies Center is open only to research groups and students. Moreover, the lakebed of Soda Lake is entirely within a Wilderness area now. Only a 30' wide corridor for the Mojave Road remains open. IOW, if we were to exit the I-15 at Zzyzx, we couldn't get through to the lakebed and couldn't legally travel on the lakebed from that point.About Soda Lake detour. Is there way from I-15 to Mojave Road through Zzyzx? Would be interesting to take a look at that place.
GSequoia said:I should be leaving straight from downtown L.A. Friday, I'm going to try to get out early (4-ish?), I could meet you someplace out your way and we can head out...
Slight change in plans...coach9119 said:I'm leaving about the same time, maybe a bit earlier from Santa Monica. Are you guys going to caravan out there? Let me know if you are and what CB channel you're on.
