YELLAHEEP
- Littleton, Colorado
How many of you MJ guys would like to see a set of lift leaf packs specifically engineered for your MJ's?
I'm currently working with my manufacturer to make our "FlexE" leaf packs available for the MJ.
Post up with your needs/preferences. Do you want 'em for spring over axle or spring under axle?
How much lift do you need?
Currently, the first versions will likely be a 0" to 4" leaf pack. The amount of lift depends on if you use it for spring under (stock height 0") or spring over (depending on spring seat height and axle diameter, up to 4" of lift).
Thoughts?
Thoughts?
