MJ on 42 Boggers continued
Wohoo the beadlocks were here when I got home from work yesterday. I went to town prepping the wheels for welding. I bought some paint & rust removal discs for a bunch of rust repair a while back so I figured I'd try them on the wheels. They work ok on rust but these things are awesome on painted/powder coated steel. It only took a few minutes per wheel to prep them, way easier than using grinding discs. I prepped and welded up one wheel last night.
It took all day but I was able to get the rest of them welded and painted today. The paint was kind of mickey mouse. I didn't want to deal with setting up the garage for spraying again so I sprayed them in the back yard. My neighbors are pretty close so I'm waiting to see if I get any complaints about the green cloud that drifted into their yard.
I was able to mount up one of the MTRs before I called it quits for the day. I almost forgot how much these 32 bolt beadlocks suck to install. I'm really glad I decided to build another set rather than swap them back and forth as the seasons change. I'll have to mount the rest of them up later.
https://www.amazon.com/gp/product/B06WVBF5QV/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
[/url]Untitled by David Nichols, on Flickr[/IMG]
Well when I got home from work and went out to the garage I found that the tire that I mounted was completely flat, WTF! I inspected it and found the valve was leaking as well as there was a pretty sizable leak at the beadlock bead.
I mounted up two more tires and had a leak at the same general area on the beadlock bead. I was thinking that this was a problem with the back side of the bead of the MTRs. I decided to try applying a gasket sealer to the seating surface of the bead and waiting the material to cure. I was able to get one wheel re-assembled and aired up to 18psi. Ill check it again tomorrow morinnig to see if I lost any pressure
Project Facelift Stage I, II, & III
Stage III, Beadlocks
Today was a good day for progress on the Comanche. I was able to complete the rest of the beadlocks, which I HATE installing. Here's a stupid fact that I wish I didn't know, since I had to install, remove and reinstall 3 of the beadlocks because of them leaking air. That means that I snugged, tightened or torqued the bolts a total of 512 times.
Stage I, Winch bumper
I installed the Barnes bumper clevises and added corner gussets and braces to the inside of the winch bumper.
Stage II, Nose Job
I removed the front half of the front fender flairs, lower front fenders and outer lower radiator support brackets. I had to cut out a fair amount of the front inner fender to allow for tire clearance. I was able to bend up the new front fender tubes and get them tacked in place.
My buddy Kevvin helped me out today by building and installing the passengers side door braces. He was also able to make the rear fender flair slider braces for me which I'll try to get installed before next weekend.
Nice I was reading this on pirate and have been following this thread since the previous owners build
