After recently doing the fan mod, I grew disgusted with having to wait 30 seconds after shutting the car off to flip the switch. Explaining to everyone who rides in the in the car why you have to sit and wait 30 seconds is more work than it is worth. I enjoy everything else about the fan mod and highly recommend it. So, I modded the fan mod to unground the famous wire after 30 seconds. This involves adding a delay-timer to the fan mod circuit. I looked into building the circuit on my own and don't feel as though it would be that difficult.
http://ourworld.compuserve.com/homepages/Bill_Bowden/page2.htm#relay_i.gif
This shows an example of what you would need. Radioshack should sell the goods for ~$15. After some searching I found a Delay-Timer from Elk Products (ELK-960) for $25 from
SmartHome.com
It was worth $10 for me not to have to build the timer.
This is a brief description of the installation:
*disclaimer* Do this at your own risk. As always, if you screw up your car, it's your fault. Be careful!
- Order your timer. I found it from another website for $20, but they didn't look as reputable.
- When you get your timer, set the jumpers like this: R3 - about half way around will give you 30 seconds
jp1 - SEC
jp2 - 1-shot
jp3 - begin
jp4 - A
jp5 - +
jp6 (if you have it) - 12v duh
- Setup the connections like this: + - Batt const
- - ground
tgr - I tapped into the lighter fuse right at the fuse block
n/o - one side of your fan mod switch (the other side of your switch should
be to the 'fan mod' wire)
com - ground
- Mount the relay-timer. (I used an empty 3in by 3in washer container made of thin clear plastic. If you don't know what I mean, go to a home improvement store and look in the hardware section. They sell washers in small plastic containers.) After mounting the timer in my washer container, I cut a small hole in the end to run the wires through. There was room on top of my PFC so I just set the container on top of it.
- Test it. Warm up your car. Test your fan mod switch. It should work exactly as before. Turn it on, you get fans. Turn the fan mod switch on for 2 min. Turn the car off. Leave the fan mod switch on. After 30 seconds (or whatever you set R3 to) the fans will go to low speed for 10min just like before. When you start the car back up, the fan mod switch is back to normal.
- Enjoy being able to turn your car off and hop out right away without feeling guilty.
Notes : I have only had this mod on my car for today, but it is working perfectly and I don't expect any problems. There are probably better ways do this that would avoid having to turn on the switch 2 min before you turn the car off. I like the way the fan mod works and didn't want to screw around with the wiring of the fan relays. The fact that the fan mod switch works exactly as before is a plus. I don't recommend leaving the switch on all the time (when the car is cold, highway speeds, etc).
Total cost: ~$30.
Total time: 1 hour.
