winterbeater
- Royal Oak, Michigan
I thought about that but it seems like alot of work to get clearance to the headers to wrap them.
What about if you already had the header off anyway?
Here's what Dino did
http://www.angelfire.com/my/fan/manifold.html
And here's the stuff he used
http://www.summitracing.com/search/?keyword=THE-13575&dds=1
I was thinking he'd used a header blanket, but it's a different product. I was wondering if something like this would work.
http://www.summitracing.com/search/?keyword=header blanket&dds=1
Both products say they're rated to 2000*F, and the last link is specifically for wrapping headers. I'd think they'd work fine on a stock Jeep.
Fiberglass coating huh? I've heard of the ceramic coating (I think that helps keep the heat down too).....but fiberglass is definitely interesting - and probably expensive![]()
In this weather it still does it?
I don't know.. heat soak in 50*... your problem may not be heat soak. That is awfully cool for heat soak to cause an issue, especially with insulation. Have you checked fuel pressure?
Your CEL code tells you multple cylinder misfire, and which cylinders are misfiring. With an '01, think of three pairs of cylinders, each pair with its own coil. If the misfire is limited to cylinders 1-2, or 2-3, try swapping coil packs with a pair that is not misfiring. Clear the codes, and see what happens.
If the code returns, but on a different pair of cylinders, you've isolated the problem to the coil pack (or possibly multiple packs). Your original code of P0303 pionts to #3 cylinder, and the link magimerlin posted gives several causes.
Does the error code change? What are the last two digits of the error code when it changes? I lean toward a bad coil pack (or two), as I have seen it happen before. You said it's all cylinders, so that would mean you've seen P0301-06? Knowing for sure which cylinders are misfiring will aid in diagnosing.
Steve
And how would you do that?
