Yeah, I like mid-arms, or just longer short arms. The issue to me is the angle of the arms, not the length, so the mounting position is the real issue. The compromise, or balance, is between arm angle, arm length, and ground clearance. I have a thing about ground clearance......basically, I won't do any mod that decreases ground clearance. By the time you set up a long arm to not significantly decrease ground clearance, you have increased the angles and removed some of the benefit of the long arms. If you draw out a couple of scenarios on the garage floor in chalk, drawing the arm positions from stuff to full droop, with the axle movement in an arc, it's very dramatic to see what setup will produce the best combination of arm angles and ground clearance.
With a mid-arm (sort of, longer short arm really), you can position the arms for good angles, and keep the mounts both forward and high enough for good ground clearance. The only negative I see to this is that you have to make everything yourself. So, if you aren't able to design and fabricate yourself, you may be better off with drop brackets or a long arm kit (ouch!). The biggest problem with long arm kits is that the LCA frame mounts are below the frame, and way back.......talk about killing break over angle.
Some of the guys who have made their own long arms have moved the mounts higher up, inside the frame rails, which is much better. Drop brackets work very well, but you have to live with the 4" lower frame mount. That can be a problem, but not nearly as bad as long arm mounts under the frame rails further back.
I think the focus should be on ground clearance because, in the big rocks, getting hung up stops you more often than a lack of traction.
Here's a link to pics of mine, the first few pics are of my old D30, the D44 pics start in the second row.
http://fototime.com/inv/DFCDB9A8BDAF591
The LCA's are 19.5", and the UCA is 17.5". The mounting position on the axle is just as important as the position on the frame.
