Mercury Villager heat problems
H8PVMT
Central Maine
a guy at work here has a villager and he can start the car and get the heat going, but as soon as he starts to drive it the heat cuts out...I have no idea, anyone????
TIA
doug
Only I have is to move this thread to the correct forum :D
OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJ' and MJ's.
are the blend doors actuated by an electric motor? or are they vaccum operated?
Also, some heater valves are vaccum actuated as well....
I would tell him to get the engine to operating temp, and then feel the inlet and outlet hoses of the heater core.
Then have him drive to where there is no heat. Open the hood and then check the inlet and outlet hoses again. When the heater stops working, where is the engine temp reading at? is it as easy as a thermostat swap?
engine temp goes to 0
he's gonna change the thermo today.
I couldn't figure where to post this but I do appreciate your sarcasm. Depending on how you punctuate the forum title it could be anything OEM any car, and also stock xj's
doug
