I'm installing an Auburn LSD and I need the Master Install Kit for the Chryco 8.25" in my 94(rear only). Any info/direction to vendor will be appreciated.:music:
I just finished insalling a Detroit truetrac in my '99 8.25. I used the superior master install kit. It confused me because it contained the carrier bearings for both the 27 and 29 spline 8.25. This kit would do you just fine. I have heard good things about Randy's ring & pinion ( www.ringpinion.com ).
If you have your axle apart I recomend you replace the axle bearings and seals at the same time (if they haven't been done in a while and you can get your hands on a slide hammer to pull the bearings). These items are not included in the install kit, but are fairly cheap from most parts stores.
