Well I went out wheeling today broken parts are as follows
1. passenger front door glass
2. Left front rim bent unseated bead
3.Horse shooed drag link
4 both front hub bearings now have play in them
But I had a helluva good time doing it
Here is the story .
It started out with heading to a trail my friend knows we were going through some trees and pop the passenger side window breaks no big deal I have a spare .we then run through some large pipes and on the other side there is a whole bunch of silt with leaves needless to say we got stuck and had to winch after winching we turned around and headed across the creek he made it .I found a large hole with a large rock at the bottom which bent my rim and popped the bead it also killed my drag link . well after we pulled my jeep out of the hole I changed to my spare and removed the drag link Then started to straighten it out before dark. on the way home I found out I killed my hub bearings.
