- Westminster, SoCal
OK, I know I can buy the rings, but I got access to some really good cutting equipment for the next few weeks (a cutting machine which takes a drawn design and cuts it out of sheet metal for me).
So can someone explain to me what is it that I need? If I understand the idea right, then a beadlock is made by having an inner ring welded to the rim and an outisde bolted to the inner ring to hold the tire.
Am I missing something? What is the size of the inner ring? (as in how much bigger then the diameter of a 15" rim should it be? Oh and how thick should the rings be (3/16" ? 1/4"? less? more?)
Thanks
Thanks
