lp d30 and various XJ parts
FYI that carrier and gears you have in that box there will not fit in that housing, and the bearings are now needing to be replaced because you didn't keep the races matched with which side they came off of. if those caps are from the 91 XJ housing they are worthless too, caps are machined to the housing when its originally assembled, if you don't have the caps for the ZJ housing the whole thing is a paper weight.
the caps in the picture are the ones off the ZJ D30 in the picture. Didnt realize the carrier wouldnt fit since my 3.73 carrier fit in the HP D30. Ill update my post.
Carrier is the same
