Larrythedog
- Covina CA
I'm trying to set up my front shocks and I have a few questions. Why are most of the Jeepspeeds front lower shock mounts so far behind the center line of the axel? These pictures all seem to have the center of the shock bolt about 2-3 inches behind the center of the LCA bolt. Is this to gain clearance between the coil spring and bypass shocks? Or is this an attempt to keep the shock as perpendicular to the LCA as possible? It seems to me that the coil spring should bow away from the shocks, is this always the case?
