BrokenXJ
- Massachusetts
What is the right way to remove the knuckle when the lower ball joint nut just spins in the ball-joint and won't come off. The BFH did not work because the lower was truely frozen, and the top was even peened over from grenading axles shafts.
I ended up getting it off by using the air chisel on the bottom of the joint and extracting the ball from the joint. I then could used the press, and hammer menthod to remove the rest of the joint.
What do the professionals do?
