Hey guys, I'm hoping someone with knowledge could give me a quick critique of my build plan. Here's what I've got so far:
'90, 4.0, AX-15
Zone Offroad 3" lift w/ nitrogen shocks
IRO double shear track bar
31" Goodyear Wrangler Duratracs mounted on 15x7's
Dynomax exhaust
Bone stock other than the above-mentioned. It's proven to be an excellent daily driver with zero post-lift driveline issues and it handles the Greens and mild Blues at Rausch Creek like a beast. In any case, I'd like to be able to run the more difficult trails, so here is what I've come up with in order to do so (the goal being to clear 35's without going any higher):
Axles:
-I'd like to stick with the HP D30 up front in order to keep costs down. It's a vacuum-disconnect model, so I plan to do the one-piece conversion first then beef it up a bit with chromoly shafts/760x U-joints and a diff cover.
-D35→D44 swap in the rear, preferably a D44 out of an older XJ for convenience.
-4.88 gears
-Aussie or Spartan locker in the front (undecided)/selectable locker in the rear (leaning towards OX)
Wheels/tires:
-35" Goodyear MTR's on 15x8 steel beadlocks. I want to stay at 3" of lift so there will be lots of fender trimming and bumpstopping.
Extras:
-JKS quick disconnects
-HD Offroad no-lift shackle relocation brackets with IRO adjustable shackles (should net an extra .5-.75 inches of lift). My stock shackles are at a 90-degree angle right now.
-2x6 steel rocker replacement
That's it in a nutshell. I think my plan would give me a very capable yet affordable XJ that could do pretty much anything I wanted it to within reason. I'm curious to know what you guys might do differently. Thanks!
'90, 4.0, AX-15
Dynomax exhaust
Axles:
-4.88 gears
Wheels/tires:
Extras:
