- Virginia City, NV
With a c clip axle correct me if I am wrong but don't you have to pull the pin to get the axles to move in far enough to get the clips off? Hence the the need to grind the pin or the ring gear.
This is correct. You will have to grind a very minor portion of two teeth in the toe that does bot contact the pinion gears. This is standard practice for 8.8 as well as many other c clip axles.
