zipjeep said:
Spray wd40 on the inside of the new cap. That should keep moisture away.
AAAAh! NO NO NO!
WD-40 is NOT conductive, and will therefore reduce spark energy available. I've run across plenty of jobs I've had where I just had to clean WD-40 out of something that someone tried to "clean" or "protect" it with.
WD-40 is not RPT
not a "miracle spray," and is damn sure not meant to be used on anything electrical!
"WD" stands for "Water Displacer" - which is what it's meant to do. It is
not a:
Lubricant
Contact Cleaner
Electrical
anything
Lock Lubricant
Part Cleaner
Or any other damn thing - no matter what the can says. I've successfully used it as a lubricant when maching steel - but that's because I ran out of high sulphur tapping oil, and needed something
now (and I really didn't like doing it - I usually use something like "Tap Magic" for that.)
Ricky - get a Borg-Warner cap & rotor from All Parts (Branham & Meridian - tell 'em Jon with all the Jeeps sent you) and stop going to Kragens for parts. I spent three years behind the counter there - and they have
not improved since. If you can, talk to Ben or Jim when you go to AP. Those are the guys that handle calls from Arabia's, and they know Jeeps fairly well (even though Jim is a GM guy...)
For electrical goodies, check OSH - they carry a decent selection of LPS (if you go to the one on Branham, check across the aisle from automotive batteries) and you'll find stuff there. Hell, you might find
me there as well - I spend more time at OSH & AP than I do at home...
5-90
