8Mud
- Central Germany
I just did a door on my XJ, pounded it out as good as I could, it was pretty rumpled. I used a random orbital sander to finish, after the body filler. A coat of sealer/sanding primer, base coat and then clear. Paint turned out well, one very small run, color was uniform.
I rushed the job a bit, I really should have done some more prep and put a light coat of gloss black on to check for low spots, but I was in a hurry (have tech and smog inspection soon).
I used to be pretty good at body work, but am a bit out of practice. I´m not real pleased with the results, it looks OK, unless you get it, in just the right light, then you can see some low spots and sanding scratches.
Would an line sander do a better job, of getting it flat?
If I decide I can´t stand it, can I just wet sand the clear and put down another coat of metalic and clear coat over the top? The base and clear I have on there now is shrinking a lot and some sratches are showing up that weren´t there last week.
If I sand through the clear and base in spots and end up with feathered patches, is the new base coat and clear gonna lift the edges? I`d sure hate to have to start all over again.
