jacked
- Torrington, CT
the wiring is all correct. ive got the car side of the module grounded to the stock ground wire, then i connected the ground wires of the led lights to the trailer side white wire. im thinking its got to be a ground problem. so should the trailer side be chassis grounded as well? also, the original grounds that would connect to the tail lights, should that be grounded back to chassis as well?
