GrimmJeeper
- Gardena, CA
dibs on one of the hayden 12" fans!
I have some tail light housings from a '92
stock control arms (all 4)
couple of Hayden 12" fans
couple of franken fans and some extra parts
a pair of stock calipers
a pair of used-to-be chrome tow hooks
a pair of 2 1/2" steel lift blocks that need a little work to be used
a stock rim (steel)
some mid 80's quarter glass for the front doors, fixed with the tracks
some power window/lock switch panels
a used unit bearing that might be usable
a set of stock front axle shafts
Ummm, stock and old.how are the joints in the axle shafts?
I have some tail light housings from a '92 (to SocallBill)
couple of Hayden 12" fans (one to Grimmjeeper, and If there's another usable one it goes to chip clip)
a pair of used-to-be chrome tow hooks (to chip clip)
And I believe ScottMcneal asked for the calipersa set of stock front axle shafts (to Souske)
Do you have some Dimensions? And your location?
Well I'd say I'd take it if Bubba didn't, but I don't think I'd want it after it'd made the trip south in Finch's XJ... And it'd be hell to fit in a Mirage. I think you need to come to SD to visit in the Ferd pickumup truck...
I'll take those rear end caps. Mine got toasted before I had a chance to make work.Side molding and rear corner end caps off my 97
