- Minneapolis, MN
The part number is between the screw holes.
...the problem I'm having is feeding the 3 plugs down trough the a-pillar and behind the glove box! ..... I've already removed one bolt that holds the glove box frame to the body right next to the fuse box.....
Grab the bottom of the dash and gently pull it toward the passenger seat. The bracket that the bolt goes through can then be slightly flexed to the right and wedged on the door frame. At this point you will have just enough room between the dash and the unibody to slip the wire plugs into place.
i went back and picked up the main wiring harness for the console, but when i went to install it they still didn't match the harnesses in my car under the glovebox. should i go back to the junkyard (far away) and get the other ones and splice them in, or should i just cut the harness off the wiring i removed, splice together the wires that are the same color, and then regularly splice the other wires to the left over corresponding wires? i noticed there were about 3 left over on the new wiring harness that aren't in my car. anyone have any knowledge of these? thanks!
i wrote the colors down but don't have them here...i'll edit later or update in this thread, but "i believe there was a gray wire, a dark blue, and a blue with white or light gray stripe. i looked in my haynes manual but it stinks and doesn't list those specific ones. just mentions orange and black and the pink and yellow power wires for the overhead lighting. thanks for any help.
97+ XJ overhead console is the way to go.
Can anyone pm me the write up on this?
