This discussion comes up like once a month on here, which gear ratio to use? . I say go as deep as the carrier lets you, gear once, because you will eventually go up in tire size, whether or not you think you wont. Its just the nature of the beast. And when you do, youll wish you had deeper gears. it happens all the time.
If youre already at 4.10, and you really really want to spend the cash to regear , Go to 4.88. But since you have already re geared, I agree with Vanimal and Id take that same money to regear and put it into a 4:1 kit or other jeep parts you need, and shop around for a good deal or get a good used case. theres much more bang for your buck at this point in time with a 4:1 kit, since you already regeared to a reasonable gear ratio.
At this point its all about opputunity cost, if you regear to 4.56/4.88, you cant go 4:1.
Or If you go regear, or 4:1 , you cant go on craigslist and get a hp44 or 60, and throw 5.13s-5.38s in there. If you do any of that, you cant use that same money to buy tube and build a cage.
4.10*4= 16.4
4.88*2.72=13.27
4.1*2.72= 11.15
If you want more freeway, go 4.88, if you want more crawl ratio on the trails, go 4:1.
If you want more beef up front, build a better front axle, or buy chromos for your axles or some 35s.
