RWKHausSupply
- yorba linda, Cali
These are complete kits. Only other items you will need will be e-brake cable, for your application.
http://www.rwkhaussupply.com/magento/steering-items/jeep-disc-brake-conversion-kit-tj-lj-xj-dana-35-44-and-c8-25.html
Fits 1991 to 2001 Jeep XJ Cherokee with Dana 35 and Chrysler 8.25 Rear C-Clip Axles.
Fits 1990 to 2006 Jeep Wrangler, Rubicon and Unlimited with Dana 44 (press work required to add spacer on shafts) and Dana 35 Rear Axle.
Dramatically Improves Stopping Power
Dual Bolt Pattern (5 on 4.5 and 5 on 5.5)
Includes All Necessary Hardware
Emergency Brake Cable Sold Separately
Kit does not include Emergency Brake cables. On non-C-Clip style axles you will need to remove the axle bearing and install included spacer, then press the bearing/seal back on to the axle shaft.
Will not fit pre- 1990ish Jeep vehicles (like the XJ D44 in 87-89).
$399
Robert
RWK Haus Supply
[email protected]
$399
Robert
RWK Haus Supply
[email protected]
