sumofatguy
- alberta
Hi everybody,
I have a 2000 XJ here with a 231 and JB conversions (I think) sye kit installed. It was installed quite a while ago, so I can't quite remember the brand.
Either way, the rear output seal has been leaking for a long time, and I've finally decided to try and fix it. My first issue is that it appears the output yoke actually has a groove in it which may be contributing to the leak.
Is this a common occurrence and what would a suitable part number (spicer perhaps) be to replace it? Is it recommended to replace this? This is what it looks like right now, it's not too bad, but definitely a noticeable groove to the touch
secondly, NAPA is letting me down here... the NAPA part numbers for the rear seals that I've found online seem to vary quite a bit, at least the part the canadian NAPA here finds for me. right now I have this seal, NAPA part number 18687, but it definitely looks different than other seals I've found online.
The other common number that comes up is 18662, but NAPA here only finds that as a two piece brass-looking sleeve/bearing?
And finally, if its decided that I should replace the seal and the output yoke, how do you pull that seal out? It seems like it will be tricky to do... Thanks!
