Thats rich coming form someone that has trouble turning a bolt. A stroker is not just displacement being changed. Its not a bolt on, so you obviously have no idea about the details of one.stock Jeep 4.0L 190HP
+add stroker to 4.6L adds 15% displacement but due to all the limitations of the jeep 12% is closer to the actual increase in HP
...say 366hp with 6 psi of boost. That is given that the stroker is putting out 260 hp (hopefully more)QUOTE]
That is your prediction, you wrote it.
...say 366hp with 6 psi of boost. That is given that the stroker is putting out 260 hp (hopefully more).
That is what several calc predict.The calcs, which I don't hold much stock in, say 366hp with 6 psi of boost.
That's clear as mud.The problem with ignore is that it lets people who aren't aware of the fact that someone has no idea what they're talking about think they are learning something when they are being misled.
Hey, just put it on a dyno. I have.
I noticed that too. Sounds like a problem with the dyno operator."can't get a clean pull" :dunno:
That has less to do with this thread then what CobraMarty is rambling about. BTW, If I wanted a turbo I would have gone that route.:rattle: FTS Turbo is the way to go. Boostwerks is were its at.
I was joking man do to all the bitching cobra has done involving super chargers.I noticed that too. Sounds like a problem with the dyno operator.
BTW, I have a pre stroker dyno run and intend to do a stroker dyno run then a SC dyno run.
Maybe he will do a turbo next so he can have something else to bs about.I was joking man do to all the bitching cobra has done involving super chargers.
