This project hasn't failed. I've just been busy. Life and generally stupid shit has gotten in the way.
1) In the process of grind the manifold I managed to make a hole so I had that welded up. So that is fixed and I still need to get to work to finish the grinding and forming.
2) I purchased some essential parts for a meth injection system. Lightly used Labonte equipment and the most expensive parts. The pump, the controller and two nozzles. I'll still need some hose and fittings.
3) I finally got around to mounting the vacuum, boost and EGT all-in-one gauge. The aftermarket mount offerings didn't thrill me. Either too big, didn't fit or just plain ulgy. So I made my own.
Most of the parts and tools besides the screws I already had so it was labor + $7.
I used a piece of 1.25" square aluminum stock, a piece of .5" aluminum stock and s piece of ABS tube.
My goal was to having something small, attractive and removable for the inspection decal.
I drilled a .5" hole in the 1.25" stock. Drilled and tapped the set screw and then went to work. First I formed the piece to accept the ABS tube. Roughed it in with a die grinder and then sanded it to shape with a piece of sand paper wrapped around a scrap piece of tube. Then I formed the other side to the A trim molding. I formed it to match the contours of the A pllar trim so it didn't distort the trim an kept it at a viewable angle from the driver's position.
After the forming I sanded it with 400 grit paper and sprayed it with Valspar. I won't use the valspar again because it takes too long to dry.
Then the tube. It was cut to 2.25" and I drilled a hole close to the end then counter sunk it to mate to the .5" piece of aluminum. I then sprayed the ABS with the Valspar. A week later tnd that shit was still tacky.
The gauge was a press fit in to the ABS as were the black and blue trim rings that fit over the gauge bezel. Tose were cut on the laser at work from scrap.
Also I did have a chance to test fit the MP90. It won't clear the hood. I'm lacking about .5". Just another lie by Rick Rimmer and JP Magazine as there is no way in hell his "kit" would fit under a stock hood.
So now I have the dilemma of having the engine mounts lower the engine, and re work the exhaust or making a slight power budge in the hood, which I already have vents in. I already need to relocate the hood latch pivot as it is directly over the MP90's pulley, which shouldn't be that hard.
