bmanga
- Marietta GA
Make me an offer I can't refuse. I have over $5k into it. Bringing home another car from Ohio and need the room. I will consider a passenger drop Dana 60, king ping, 4.56 as partial trade....
Details:
1990 Jeep Grand Wagoner
Most parts installed or included were purchased from BJ’s Off-road.
Mechanical
- AMC 360
- 141k on it
- Just re-torqued heads
- No sludge in heads.
- 60-75 psi of oil pressure and 40-50 at idle.
- Great compression in each cylinder
- New Poly motor mounts
- New rear main seal
- New oil pan gasket
- New radiator fan guard.
- New mechanical fan clutch
- New belts
- New Edlebrock chrome valve covers
- Rubber valve gaskets.
- Stainless steel hex screws used on valve covers
- New MSD Billet Aluminum HEI distributor
- New Accell 8.8 mm yellow wire set
- New Champion Spark Plugs gapped to .45
- New K&M 12" air filter
- New Stainless Steel braided fuel lines.
- New Power Steering hoses
- New radiator hoses
- New Edlebrock roller timing chain/gear set
- New cam gear to drive HEI
- New HEI distributor gear
- New water pump
- Rebuilt Oil pump
- New Oil pump steel mid plate
- New Stainless Steel oil fill tube.
- New Howell TBI kit
- Chevy based kit
- Chevy based computer
- Closed loop system
- O2 sensor based.
- New Ford style electric fuel pump
- Mounted in a protected area of the frame rail before tank.
- Fuel filter mounted near the fuel pump (easily serviced)
- TF727 Automatic Transmission
- Shifts great
- New ATF fluid
- New filter included
- Factory cooler since it has towing package
- New NP 208 transfer case
- Less than 200 miles on it
- New fluid
- New Manual Warn hubs
- Brand new Rancho steering stabilizer
- New gas tank sending unit.
- New Ujoints in longer rear drive shaft
- MagnaFlow dual chamber muffler
- Brakes
- New pass side caliper
- New brake pads
- Rears are brakes are in good condition
- Axles
- Front Dana widetrack 44
- New gear fluid
- New vent line runs into engine bay.
- Stock gears (3.09 I think)
- Rear Dana widetrack 44
- New gear fluid
- New vent line runs to highest point over gas tank/rear
Tires
- BFG ATs
- 5 32x10.5x15’s
- 98- 99% tread
- Mounted on factory turbine wheels
- 100% tread on matching spare
- Mounted on a white wagon wheel (spare) Rides on Tad rack.
Lift
- 4” full spring lift
- Rear springs are SuperLift
- Front springs good shape(think they are RC or Heckthorn)
- Poly bushings
- Relocated tracking bar in rear
- Braided stainless brake lines front and rear.
- No bump steer
- Sway bar quick disconnects
- Shocks (RC I think, possibly Heckthorn)
Exterior
- New window rubber swipers in doors.
- Full Tad Rack (made by Tad Strickland aka safari rack)
- New Pro Comp 6” lights where factory ones go
- New Pro Comp 7” stainless steel spotters up top
- Razor grill conversion.
- New Hi–lift Jack
- XTrac mounts on Tad Rack
- 78"
- Red
- Hood bar painted and ready to go on.
- Wood grain siding in great condition
- New Hitch clevis with D ring.
- New Front Hook mounted on pass side frame
- New poly bushings in sway bar
- New sway bar quick disconnects.
Interior
- Burgandy Leather in good shape (see pics)
- Burgandy carpet in good shape
- TBI diag port
- TBI diag LED
- Power mirrors
- Power windows
- Power door locks
- Power rear window
- Power seats
- Manual vent windows
- Rear defrost
- Roof cross sections/mounts re-caulked for less vibration/noise
- Sony AM/FM/CD/MP3 Radio
- 4 Boston acoustic 5 1/4 speakers
Known Caveats
- Window motors slow
- Door locks don't always lock properly
- AC needs work
- Evaporator has a whole in it
- A used evaporator is included.
- Headliner
- Is currently out.
- Cardboard in good shape but needs new material.
- Factory arm rest included. Currently a Center console I got for free is in it. Not that great of one.
- All trim pieces included.
- Rear seal in TF727 needs replaced.
- Rear window works via dash switch.
- Rear bumper passenger side is pushed in and minor damage to lower corner.
- Slight rust bubble on front passenger fender.
- Gas tank skid plate has some rust and decay near edges.
- Hood faded
- Needs exhaust tubing redone
- One header bolt needs replaced. I think it broke off in block but not 100% sure.
The hood bar is not in the picture below but is now installed. Runs good but needs some fine tuning.
More pics of interior and motor in this thread: http://offcamber4wd.org/forum/index....c=5250.new#new
Details:
Mechanical
- AMC 360
- 141k on it
- New belts
- New water pump
- Rebuilt Oil pump
- Chevy based kit
- O2 sensor based.
- Shifts great
- New ATF fluid
- New fluid
- Brakes
- New brake pads
- Axles
- New gear fluid
- New gear fluid
Tires
- BFG ATs
- 5 32x10.5x15’s
- 98- 99% tread
Lift
- Poly bushings
- No bump steer
Exterior
- New Hi–lift Jack
- 78"
- Red
Interior
- TBI diag port
- TBI diag LED
- Power mirrors
- Power windows
- Power door locks
- Power rear window
- Power seats
- Rear defrost
Known Caveats
- AC needs work
- Headliner
- Is currently out.
- Hood faded
