Well here is my build thread. Hope I can provide some helpful insight where needed. I am starting out with an 89 XJ that I bought from olivedrabcj7. It came with the puke gut trans and 231. It had a 3" lift on 31"s. For later reference though I am going to run the drive train that is currently in it until I break something and I know I will but I am on a budget so I will deal with it as it comes. I do not go EXTREME crawling all the time. I want to have soemthing to play with in the woods and go on some rather extensive trails with some crawling but not solely for that purpose. Basically I am starting out with a Dana 70HD rear and Dana 50 front. I know I know I know about the 50 but it will suffice to get it lifted and I will change it once I have a $K to drop on a 60. I have 4 front leafs from a 76-87 Chevy which measure 44" ete. They are designed for 12"s of lift for that truck and I know it sounds like alot but they are very similar in design to the 44044 but with 3 more inches in height. I bought 2 sets of mounting brackets from ballistic and some front bumper mounts. THANKS guys great stuff. I also have four revolvers for it and here again I know I know I know just trying my options. I picked them up cheap. My welding holds well a little messy at times but strong. I will describe each pic below and if you have any questions feel free to ask. Thanks
This is when I first got it and some of my friends decided to have some fun with tape and things while I was gone for the weekend. And no I am not mexican - long story
Finally got it halfway cleaned up and back to my shop after I put a fuel pump U joints and a harmonic balancer on it.
OK here is the deal with this. I have the lame puke gut transmission that the mount costs more than the trans is worth. I basically wanted to go play in the jeep so I rigged this up. It's a bolt with a stack of washers in between the two plates of the mount. Suprisingly works quite well after hours of thrashing on it.
If you notice here I have moved some things around so that I could place my overflow next to the radiator. I did the GDI swap and I am in the process of adding the 10" fans for awesome cooling.
The first of disassembly.
Hooray I bought a sawzaw
This is my bumper that I "made" It is 2X4 steel 65" long I think. Simple enough. Use 8 grade 8 bolts in factory holes. Slim and strong! Fits perfectly in that groove if you have ever looked behind the bumper.
