vetteboy
- morganville, nj
JamesD said:I understand that you all are "trying" to help but*&$^&^$%UY^%$^&$# when someone tells me to cut everything up that I have done when they told me to do it I get kind of pissed. I don't have an extensive budget like some do and I am working with what I have and if they don't like it I will gladly take donations of whatver their endless budget allows. I understand that I am unorthodox in sorts but instead of basically saying I am a %())&$%$ idiot and telling me to start over after I have searched and this is what I ended up with, I only ask for ways to help me improve not a total reconstruction. I did search and I did ask alot of questions and you know what I ended up with is everyone telling me for simplicity use in boarded leafs all the way around and plate the "frame" and you know what, I am doing exactly that. CRASH you even said it yourself so I don't understand why what I am doing is so wrong. Disregard my welding capabilities because I trust it and I know it will hold. And regardless what you say I have taken your suggestions to heart or I wouldn't be doing what you said. I know the whole conv. about the Dana 50 but you know what I have 100 in it so it has to work for right now. I am not looking for praise as to what I do I am just looking for suggestion as to make it better and I don't understand why a total reconstruction will make it better when I am doing what is suggested. I have established the fact that I need to do some redesign on my rear mounts at the first time that someone posted about it. Please if you have concern then bring it up and try to help with it not be negative.
I've said this before:
There are three things that come to mind when building a rig like this.
- cheap
- reliable
- trailworthy (intended to do extreme stuff beyond stock capabilities)
In a given build, you can only ever pick two of these. You seem to have concentrated primarily on the 'cheap' part and disregarded the rest.
Inboarded springs isn't a fad, it's not a fashion statement, and it's certainly not something you do just because someone else did it. From your pictures you seem to have relocated the spring hangers about 1" inboard and about 3" further to the ground. Seriously, what benefit does this give you? Is your only gain here that you don't have to cut and reweld perches on an axle? You'll have to do that anyway to make your driveline angles correct. Meanwhile you've compromised ground clearance and frame rail structural integrity for what appears to be very little gain. If there's more to it that I can't see from the pictures, then by all means, post up.
It's also statements like this that confuse people:
No, it doesn't. You telling it that it has to work doesn't make it behave any better. Meanwhile you're stuck with crappy leaf spring placement and a weak axle that'll leave you stranded and spending more cash just when you're trying to enjoy the fruits of your labor. Whatever happened to your eBay auction for this, by the way?
Another thing I've tended to notice so far is your complete disregard for material section properties. The two most common things used to brace the frame rails are 3x3x1/4" angle and 4x6x1/4" box cut in half. This is what you'd find on a search on the subject. Both end up going nearly to the floorpan along the frame rail. Why? Because the vertical part is what lends the most bending strength to the section, not the flat part on the bottom, and it connects right where the unibody rails connect, at the floor. What I see at your spring mounts is a clusterfuck of c-channel, flat bar, angle, and rust that doesn't really give anyone a clear idea of how you've actually gone about reinforcing things there. How have you welded it to the unibody, and why didn't you cut it to length beforehand?
I'm also guessing that you'll be removing the rear wheelwell area due to the extended wheelbase. I hope you appreciate just how much structural integrity you've lost by chopping both the roof and the wheelwells. I did both of these, and I could grab the rear deck area and move it up and down a few inches by hand without moving the rest of the truck. Definitely not what you want for something that'll see a lot of force. You'll want to include some diagonal bracing to forward of the rear deck area, tying all the cage hoops into each other, and likewise connecting all of it to the rear frame rail area, and certainly the bumper if you insist on using it for spring mounts. And please, if you do this, make some real mounts there. I've already highlighted the disadvantages of welding to spring steel, and if you don't understand the benefits and inherent safety of rigid suspension mounting points, please post now.
Lastly...don't get pissed just because you went ahead and did a whole bunch of work when you thought you were following advice. If I told you to go fly a plane, and you did so and crashed it, by your logic you'd be pissed at me because I planted the idea in your head in the first place. Nevermind the fact that you failed to adequately research and implement what you were doing (I believe I suggested doing more research in a few posts). Just because someone said stretch the wheelbase and inboard the springs does NOT mean that any way you can come up with to accomplish this will be a good idea. I'm not saying my buildup is perfect, because it isn't. But very few (if any) are, and the fact that I've built a few suspensions under this jeep and on many other vehicles already gives me a little bit of confidence in what I'm doing.
Bottom line is we're just trying to save you a lot of problems in the future. There are people on this board which much more experience than you (and even myself!) and it would be nice if you could show some consideration for their advice every so often.
And if not, there's a fellow by the name of StrokedDodge over on Pirate that could probably give you some good buildup hints as well...
