KimberleyCrusader
- Broome Western Australia
Hey ppls,
Just finished installing these components for a 3.5" lift except for the transfer case drop kit.
OME 930 - OME(Old Man Emu) 2" coil springs
OMEJC2A/B - OME H/D rear leaf packs
JCXL OME - additional leafs
N35L OME - extra long shocks front
N36L OME - extra long shocks rear
OMEU57 - OME longer u-bolts
RE1334 - RE coil spring spacers
RE1383 - 3" Front bumpstops
RE1467 - 4 degree shims rear springs
RE1515 - Rear s/steel brake line
RE2700 - RE extended greasable shackles
SUB/PANTIE - Front adjustable panhard rod
MP/TIEROD - Tie Rod End (genuine)
I was going to do the xfer case on the w/end.
I went for a slow spin round the block and I'm getting a knock from the xfer case or the rear, not sure. It only occurs on deceleration?
Do you know what it is?
Is it safe to limp it to the tire shop and back(7mile)?
My Baja's are sitting in the shop waiting and I was hoping to get em fitted, then home to do the drop kit. Plus the tires will give me a little more work space under car.
If they're not fitted tomorrow It will be another week(been two already) before it can be done. :doh:
Thanks
Thanks
