IPF Headlight Harness
juicexj24
USA
Anyone know of a cheap place I can get a IPF headlight wiring harness cheap. Rocky Road is 89.00 Anyone know of something cheaper. I'm upgrading the bulbs and have a ground problem with the stock wiring. *Don't want to make one, to much trouble* Thanks Juice
What about using one of those kits from Schucks or similar??
Hella also makes them, and I would assume that PIAA would also, but they probably want more than IPF.
I personally do not see paying for a kit that the parts can not cost more than a few bucks. How long does it take to solder a few ends on some wire and connect them to a relay
Michael
i got one that i never installed, ipf. i dont remember how much i paid, but i will sell it to you for $70 plus shipping if you want. i just never go around to installing it. my lights work good with out it. jack
Prolly the cheapest one out there is the APC harness -- should be available wherever good rice is sold (try PepBoys, they recently signed with APC's distributor...)
Try this place...
http://www.suvlights.com/
Click on the headlight link on the top left side of the page, and some wiring harnesses will pop up. You can use the universal one listed for $45. I've got a similiar one that I ordered through a group buy a while back. Pretty much plug 'n play.
Ivan
If the problem is just grounding, you don't need a whole new harness. Just use a Scotch tap-splice to tap a parallel wire off the existing ground, and run that wire to the engine block or a clean place on the chassis.
