Another thing to consider is the tire's Load Rating. My '96 Country came with 225/70-15 tires, while most other XJs came with 225/75's. The originals on mine were a rating of 100T, with the 100 representing the load, and the T is the speed. I now have 235/70s on it, meaning 10mm wider, but about the same circumference. The problem is that an XJ, normally loaded and driven, isn't heavy enough to need this relative stiffness, so the cure is to reduce the pressure a hair. The door jamb sticker shows only 215/75 tires at two different loads, and suggests 30 PSI for both! I usually run at 32PSI, as a compromise of comfort and MPG, although at 28, they don't appear to be any less inflated.
