Important
With around 3" my 31s fit, just need bump stops. Also adjusted the stops on the knuckles to cut down on LCA rub
Sent from my HTC6525LVW using Tapatalk
If that is 3" lift equipment, once you mount those tires, my guess is they will only be around 30" tall so you'll be fine.
Mastercrafts run on the small side. Going to be a nice setup
Some shiny new parts did show up at my house from the good folks at IRO:
I guess I have plans for this weekend. Hopefully if I put all these on I can fit these:
And keep my beloved factory plastic pieces. Any suggestions?
I'm actually looking at getting these tires. Only 135 shipped, 10lbs lighter than mine and seem to have good reviews.
Amazon prime. 2 day tire delivery. I was looking at your Goodyear but these are cheaper. For a wheeling rig I'd keep the Treadwright tires but for DD I want something litter and better wearing.
Stay away from mastercrafts then. Buy a better tire if you are worried about wear. Or an AT.
Mastercrafts tires have been terrible since they changed over the the AXT ,MXT, CXT design. They will wear worse than your Treadwrights easily and they will be much louder on the road. if you don't rotate them every2-3k miles max you are going to hate them.
Before Josh chimes in, add for the day
I have the older A/T Treadwrights in a load range E on the Expy, them things wear like iron. They do flat spot a touch when it's really cold.
Sent from my SM-S920L using Tapatalk
I suggest cutting the factory plastic pieces.
Shoot cutting plastic would just lead to cutting metal.
The front coils are actually 4". The add a leafs are supposed to net 2". With my lift shackles and relocation boxes, I am hoping to match the 4". I do have an extra set of XJ springs, so I may add the main leaf to the mix.
I agree with all this. I would not have bought them except for 2 reasons. They were cheap ($400) and only had to drive 12 miles to pick em up. Secondly they are temporary since I plan on giving in and cutting some plastic (maybe metal too) to fit 33's by the end of summer.
